This summer I installed a Weber 38 with electric choke on my 1980 Mustang with a 200 six automatic. It ran great until the weather cooled off in the late fall, about 40 to 50 degrees F.
When it comes off the choke it stumbles and bogs for about 15 minutes. My mechanic says that because there is no warm air whatsoever heating the carb during warm up, it will run rough after the choke comes off till it is fully warm. He pointed out that tall Clifford carb adapter is actually still very cool even after a 25 minute run into the City, so I suspect he is correct. There is really not much to adjust on this carb.
He suggested reinstalling the warm air intake tube that runs up from the exhaust manifold, to an original air cleaner housing from a Pinto or Pinto based Mustang, as apparently they also used a 2 barrel Weber. My air cleaner is an open type, no warm air preheat at all, at any time. My original carb was the single barrel 1946 Holley so that air cleaner housing won't work.
Any others with this experience, or any advice regarding the air cleaner switch? Any other Fords that had a 2 barrel with a stock air cleaner that might fit the Weber?
Thanks.
Thanks.
