Mike sent me my new cam and a dial indicator and degree wheel set to make it goes in just right this time (and thankfully a how-to video
) . BTW, Mike rocks in case you didn't know (www.fordsixparts.com). I allready have his double roller timing set where the crank shaft gear has many key ways that are numberd (0, +2, +4, etc)
Anyway, Mike suggested I dial it in 4 degrees advanced. I'm not 100% i know exactly what that means. In general I do, but the HOW is my question. I installed the gear set with the crank keyway for 0 matched up with the cam gear dot on absolute TDC as determined by the dial indicator. By following the degreeing method in the video I come out with:
110 degree lobe center (as advertised)
Intake: 114 degrees
Exhaust: 106
Based on the video's info, that means my cam is installed 4 degrees retarded.
Just to confirm (and to make sure I didn't goof up the easy part), the SECOND lifter back from the front of the engine is the INTAKE on #1 right? If I did get that backwards and the FIRST lifter is intake, then I'm balls-on in good shape at 4 degrees advanced.
However, if I'm right, then at 114 degrees I'm at 4 degrees retarded. How do I fix that? The video uses drilling the gearset and installing offset bushings. I don't want to do that! Do I have to OR can the alternate keyways on the crank gear be used to alter this?
I THINK I understand how. If I were to slide the crank gear on at +4 degrees then line up the 0 degree mark to the cam shaft gear dot, that would be +4 degrees right? Since I really need to go a full 8 degrees the other way (4 to advance to 0 and 4 more to get to where Mike suggested), I would need to put the gear on at +8 and line up the 0 and the dot right?
Thanks all!
Intake: 114 degrees
Exhaust: 106
Thanks all!
