Simon, i will check out the crow cam dizzy gear. in the us do you have a contact in your country for this improved gear.
One fix we have in the states is to use a hack-saw blade & cut a .060 grouve in the lower oil ring in the dizzy. this .060 slot lets oil pressure to spray onto the dizzy gear & camshaft mating surface. the cut has to be cut to spray oil to the contact surface of the two gears. hope this helps.
please give me info on the crow gear for our usage in the states. thanks william
