Hey Guys.
I started this project about 12months ago, I haven't made a lot of progress due to customer engines and other jobs, but I hope to get back to it in the next few months. It is a modified Barra head on a 250 Pre X Flow block.
The head now bolts to the block after plugging re positioning the head bolt holes, the oil and water galleries are sorted. Next step will be setting up the auxiliary shaft (former camshaft) machining a new front timing cover for a timing belt drive, followed by water pump modification in conjunction with timing belt assembly.
These photos were taken right at the beginning to see if it would even be possible, so please excuse the grubby block and head.
Watch this space.
I'm also putting Barra heads on a Windsor but that's a story for another day.
Cheers
Andrew Cox
Cox Custom Mechanical
Watch this space.
Cheers
Andrew Cox
