69stang_250":2tufruko said:I just bought a MSD 6LA module and will post some pictures of the install.
And that's going to feed resister wire; 12v to coil, how ?69stang_250":1hrs9y1u said:Well as long as I wire the 12V and ground wires straight to the battery I shouldn't have an issue with it. I think it will be the easiest install and fit my application very well.
chad":5cxcvnlk said:"…Honestly I can't tell a difference - now my engine is stock, but still...cold starts, idling... The ONLY difference was that when my carb's idle circuit was going WAY lean and fouling the #6 plug the MSD would keep firing through all the crap, but otherwise with a proper carb it's fine…."
"… with a proper carb."
which carb? That's swapped out now? to what?
No longer "going way lean"?
The MSD is just so expensive for me…
