gavincorneliusedmonds
1966 Mustang 200cid engine with Carter YF 1 barrel carb. I recently had some ignition problems which were resolved by replacing PCV, Plugs, and cleaning the distributor cap. This weekend I was driving in the Connecticut hills and after driving for ~10 -15 mins, if I let off the gas pedal and let the engine idle it would slowly decrease rpm and stall after about 10 seconds as if the engine was flooded. I would not be able to start it again until it cooled and the system drained, or if I held the throttle down and then cranked it (after tinkering with the mixture screw and using some starter fluid... Not ideal I know but it was midnight and freezing at a gas station and I needed to get back to the city.)
Not sure where this issue is coming from, any pointers would be great. My online reading indicates a fuel filter issue, float issue, or there is dirt in the needle. Too cold outside to be vaporlock.
