LameHoof65
I have read a lot of information on this forum of how imperative it is that you get that new cam broke in right. With that being said, it has also come to my attention that spending too much time trying to get the engine to turn over on initial startup can do untold harm to that new cam. This alone begs the question----what's the best and most likely setup regarding carburation, distributor and timing that will most likely get you fired up on the first, second or heaven forbid the third turn of the key?
I have a 5200, a 2300/500 and of course my old autolite 1100 sitting in the garage. I also have the duraspark setup and the old centrifugal-vacuum advance/points distributor. Now I know that old distributor works and I am pretty sure the 2300/500 works...Wouldn't bet on the 5200 I rebuilt as it was my first ever rebuild....though I was definitely meticulous about doing exactly as the instructions delineated---I have been known to make a mistake or two.
My 2300/500 was built by a guy I don't even know---it appears to be in great working order and looks clean as a whistle. From what the guy told me it was built with a brass float, 70 mains and a 6.5 power valve, it has a manual choke.
The 5200 has the heat choke, and what ever is stock for the mains and power valve on a 71 pinto 4 cylinder engine---I just cleaned them and stuck them back in.
Now, I also have the duraspark II and module, however they are both used, I cleaned them up and inspected them for rust and slack/play in the shaft and there is none and no missing teeth.
My thoughts are go with the old distributor and the H/W 5200 on start up and breakin. Anyone have other opinions, ideas or suggestions.??
Don't get me wrong, I still have things to do before I get to this point, it's just that I don't like to wait until the last minute and not have any idea of how I am going to tackle this.
