Falcon Ranch
New carb or old carb, it doesn't matter, you're not putting the water in the float bowl, you're just injecting the water into the air stream...no damage done...when the water is introduced to the combustion chamber and the fuel is ignited, the water turns into a super heated pressure washer and some of the water molecules are actually ignited into hydrogen which burns very quickly and hotter then gasoline which will help remove the carbon build up....this is why you need the rpm past 1500rpm because when you introduce the water, it will want to die cuz you are decreasing the air to fuel ratio.
Dave 8)
Dave 8)
