holley carb
how hard is it to rejet a holley 1940 [ I THINK } carb? my 200 seems to be running lean even with the air screw turned most of the way out. do I just try different sizes till I get it right or is there a better way?
thanks, kevin
HI
If your talking about the fuel mixture screw it only effects the idle mixture.
maybe float level, fuel filter pluged, bad fuel pump..
Tim
ok, how do I check and adjust the float level
thanks kevin
