I see now what they did.
You can indeed do as you have suggested: use the "dot" on the cam gear and whichever mark you desire on the crank gear.
Look carefully at the relationship of each mark on the crank gear to the tooth above it. It is readily apparent that the position of the notch to the tooth changes incrementally as you go around the gear. This will indeed give an advance/retard depending on which notch you select.
You may use the +4 notch on the crank gear with the "dot" on the cam gear exactly as you said earlier and this "should" advance the cam 4º.
THE ONLY WAY TO KNOW FOR CERTAIN IS TO PROPERLY DEGREE THE CAM!
Joe
Joe
