That is correct. In some OE cases there is a solenoid connected to the underside that can connect it to the same vacuum manifold location so Engine Management can kill boost like between shifts or if there is a problem but we don't care about that.In OE use, it looks like the vacuum side of the actuator, is hooked between TB and SC, with no other input?
Between spring tension, preload, arm length/angle, it should allow for a passive off-boost bypass, no?
