That's what I was assuming. Would it be good up to 10psi you think?A fixed retard may work ok for very low boost but would be way too big of a jump for high boost.
You need a linear retard.
NoThat's what I was assuming. Would it be good up to 10psi you think?
I guess I'll just go with the 250ci seeing as I already have it.Have you decided between a 200 or a 250?
As long as they have one that fits my needs, Clay Smith Cams.Where will get a camshaft for this project?
You saw what happened to 67straightsix in the first thread in this section titled "Turbo 200 Build"As long as they have one that fits my needs, Clay Smith Cams.
probly repeating former post :That's what I was assuming. Would it be good up to 10psi you think?
Seems I remember something about this. I will check.You saw what happened to 67straightsix in the first thread in this section titled "Turbo 200 Build"
He asked for a turbo cam from Clay Smith for his 200 and got a profile that was so far off I couldn’t believe it.
It was 244/236 @ .050" on a 115 LSA.
It idled extremely rough, had no power below 1800 rpm and didn't pull till 2800 rpm
He ended up removing the cam and finally getting a profile that worked from Schneider.
This time 224/220 @.050 on a 112 LSA
Engine idles smoothly and the turbo has a much better response.
The 224/220 @ .050 on a 112 LSA would work well in a 250
You need to call and see if anyone is still grinding flat tappet cams for the 200/250.
Check with Howards Cams also.
If not check with Delta Cams about welding and grinding the stock cam to the 224/220 specs.
You need to check on getting a camshaft before you do any other planning.
Obviously the engine will need a camshaft in order to run.
The compression will be determined by the new forged pistons so not a problem.About the low compression factor, assuming that neither the head or block have been machined, is the compression low enough with a '69 block and a '73 head to prevent detonation? I'm assuming no
. for .
.'cheap setup from Buick 231 V6 on a 250
