Timnmelinda
Changing valve cover today, ran into a couple of questions:
67 Mustang 200 automatic
There is a line going from the carb, or under it to the back hole in the top of the valve cover, as I am changing carbs to a 2 bbl anyway, do I just put a breather in the back hole?
There was another line going from the carb or under the carb to the drivers side towards the firewall, this line attached to another line that appears to go down and to the transmission (I did not crawl under to verify at the firewall it is a small copper line, at the carb side it is a larger rubber hose) So what could this be? My assumption is that it is some type of vac line? (No it is not a fuel line I do know that much)
Any help or suggestions is appreciated
Tim
Tim
