the compressor wheel does a good job of breaking up the droplets out of the carb, but the problem is they like to condense in the compressor housing again!
matt1967":16o73og0 said:the 500 CFM 2bbl would work on the draw thru? also what thickness steel plate
Linc's 200":hssmms4l said:matt1967":hssmms4l said:the 500 CFM 2bbl would work on the draw thru? also what thickness steel plate
1/4 thick plate steel.
The 500 will be fine, but you have to externally reference the power valve on ANY draw through carb to the intake manifold.
Reason for that is under boost, the carb will still see vacuum (suction) and will go lean
The factory 3.8 buick carb I have is already externally referenced.
I think they use a hard line. the boost refrenced Q jets are available rebuilt for around $300 fom www.rockauto.com just look under 1978 Buick Regal SportCraigS":3of5zlr7 said:How is the factory 3.8 carb referenced for boost? I have the turbo setup, but not the carb yet. Was thinking of just getting a stock carb. Do they use a hard line from the carb to the compressed side of the turbo, or what?
YanesRacing Venezuela":286me9rh said:but not as(like) do with the carb if someone explains to me
Anlushac11":2kq2hdux said:I dont see that fitting on my Fox body![]()
