nitrous?!
so ive been thinking about running the offy 3 carb intake on my 6 cylinder and i was also thinking of adding a small nitrious set up to it, whast the best way of doing this? just drilling right into the log under each carb or has anyone built a plate system for 1 barrel carbs. let me know your ideas guys. thanks!
Ha ha ha. That's an exciting new prospect!
The Offy takes away the space to fit six fogger nozzles, so your better off getting three fogger nozzles and three holes into an area bellow the three carbs. You'll have to find a spot where you can drill an access hole so it will fit up withoout fouling the throttle linkage.
I suspect that may have the nozzles pointing in odd directions, but "thats life, Jim".
Three conventional Holley 2-bbl plate set-up won't work.
