67coupe200
Active member
67 i6 200. original points ignition, damper and timing chain still in use.
that being said at certain rpms the car would jerk on the clutch and drive shaft back and forth until i either let off the gas or accelerated, this would occur at a constant speed only or cruising speed rather. Thinking this might be some kind of timing issue i went to inspect and gap the points as well as check ignition timing. When i started to check the ignition timing with my timing light i noticed that the flash on the light was erratic and not proper so i proceeded to advance the distributor in an attempt to fix the problem, when i did so the light stopped flashing all together so i checked the other cylinders and the first three were not firing but the last three were firing in a healthy constant speed?!? So i double checked the timing, point dwell, and the vacuum advance. all seemed well except the advance was not functioning, but the first three wires were not firing at any rpm.
After tweaking the distributor i got the first cylinder firing erratically only now the 2nd and 6th cylinders weren't firing. After that i left it alone and now here i am without a mustang
I'm leaning towards the timing chain but i cant be sure, What do you guys think?
