I poked around and couldn't find much specific, and not recent.
I've been playing with dampers lately, looking at doing a serpentine build. I'm looking at everything from adapters to bolt a pully onto the face of a stock 200 1V damper or slip a Taurus pulley over it, using my Aussie PowerBond PB646 EF/EL balancer, or adapting a straight six damper off a BMW. But I wanted to check to see if my understandings were correct.
The lighter a damper, the faster the engine revs but the more vibration it has to endure. Also frees a hair more HP?
Heavier is the reverse, slows revving and lessens vibration, costs HP. (Maybe. Fluidampr says efficiency frees HP and torque).
It's important that the weight be malleable (Not sure of the term?), either via viscosity (Fluid dampers) or connected to the hub by rubber (Two Element damper). Just a solid weighted assembly with no kinetic 'give' wouldn't be able to store/dissipate the tortional vibrations, right? Also, a 9 pound damper with most of the weight in the outer ring would damp more than a 9 pound damper that has a 1 pound outer ring and 8 pounds of hub and hub mounted pulley?
I saw a post by Bob about milling down part of the damper V ring and the conversation was about safely lightening the damper and it's effects, but what about heavier? How heavy can/should you go?
My stock 1V damper weighs 3lbs, 2.25oz.
The Hub/Snout alone weighs 1Lbs, 5.41oz. (I have one I pulled apart using the wrong puller).
My PowerBond serpentine damper weighs a mighty 9lbs, .22oz.
My BMW damper is 8lbs, 1.31oz. with the bare Hub that would be 9lbs, 7.72oz, plus a little more for an adapter.
My slipover Taurus pully is an even 2Lbs, a little more for an adapter, so over 5-6lbs.
My aluminum face pully is almost a pound so with a stock damper and adapter, probably close to 5lbs.
Also, I notice the stock Taurus damper is 6lbs, 2.40oz, and the ID and keyway are the same as the 200, just thicker OD (1.875" vs 1.750") and longer (by .500"). It seems possible to chuck the hub in a lathe and slim/shorten the snout for the 200 cover, then with an adapter flip the pulley to be a slip over rather than face mount?
I'm just noodling options to ease the accessibility for a serpentine for the 200ci. The Aussie damper was 188.42 shipped, which isn't bad, but 88.42 shipping just feels like a lot. I'm using the opportunity to work on my Fusion 360 skills, hoping to design my own WP pully and Alt bracket/tensioner mount.
