Which spark tables should I be looking at? I assume this is the primary spark table?Pull the spout connector and set it to 10° btdc. Changing the distributor will affect your injector timing. You can then open the primary spark table and just add 4° across the board.
I cruise around in ethanol free 87 and when I haul things I switch to my back tank with 93 premiumYes what kind of fuel do you run in Texas?
Awesome, thanks again efloth. Going to get a new radiator, powersteering and a bunch of cool interior stuff installed in the next coming weeks. Thanks for all the guidance, I truly would still be trying to get the dashboard to work if you hadn't responded. I'll let you know when I am ready to start playing around with dashpot and idle air.I have the amazon 4-row and I'm on the second one that is leaking as well.
I run this on e85. It's not even funny how much this engine is knock limited. You can try this on 93 but you may have to pull a bit out if she starts pinging. I also added 4 degrees across the board on the MPG spark table. Make sure you set base timing back to 10 first.
Okay I got a new AutoZone Duralast 2 row in the truck for the time being. Seems to be running a little hotter at idle, but I didn't flush the system tbh. I'll probably be replacing this entire coolant system soon so for now, a Band-Aid.
I haven't had a chance to reset timing yet. Might have to bite the bullet and buy another light because my buddy doesn't know where his is, go figure. I want to do the spark and dashpot tuning this weekend though so I will probably head to Harbor Freight in the morning to grab a new one.
I got some new interior pieces this week. Unfortunately, the new dashpad is red and the interior is burgundy! I think I am going to take everything out and spray it all with SEM 15063 burgundy color coat.
New cluster installed with a tachometer and LED's and a new OEM radio with BT added. I need to get a new harness for the radio though, the PO installed a aftermarket radio and absolutely butchered the wiring.
New window handles come tomorrow. Next up on the list is window tint, new vinyl or rhino mat floors, bench reupholster and a windshield.
Pretty sure the ABS light has to do with the fact that when I brake the right side pulls hard. I think the front left brake is stuck open.
Hmm, well when I do my entire brake system in the next couple weeks and hoping that will make the light go out. I recently replaced the VSS on the rear diff and it made my speedometer work again.This is some great information! I always thought that tuning the stock ECM
These trucks have ABS on the rear only. They use the same speed sensor that the speedometer uses which reads from the tone ring on the rear end.
This thread has opened my eyes to tuning the ECM on my '95. Definitely something I'll be doing in the future!
Where did you get the OEM style radio with bluetooth?
I ran a ECM test earlier today and was met with the GLORIOUS code 111 SYSTEM PASS I can’t even begin to express how good that felt hahaha!Sounds like you're referring to monitors like odb2. Those don't exist in this case. Keep alive memory on these stores fuel/air corrections and trouble codes
I was referring to the ability to know when to set a code for a sensor that isn't operating within its acceptable range. Like if the TPS still passes a snap test but now it reads at a low, at idle range because the adjustment of throttle blades has it reading that way. Would it set a code?Sounds like you're referring to monitors like odb2. Those don't exist in this case. Keep alive memory on these stores fuel/air corrections and trouble codes
Nice! I see there are no exhaust rotators! Is that a broken stud in the head?I found a rebuilt HD long block that came from an airport. Going to get it tomorrow!
