green streak
Active member
The wire leading from the coil into the distibutor is coming apart at the hard rubber junction where the wire enters the distributor. Can I remove the junction or does it contain a resistor of some sort. I want to run a wire directly to the dizzy from the coil. Is that OK?
Thanks in advance, Greg
