Alright Slade...no secrets. Tell me how you did it.
I have the cable setup so I get a nice straight on pull (it is not very pretty but it works). The problem is that the V8 pedal rod does not give me enough pull. It does not even open up the primary valve completely. If I tilt the rod all the way forward so as to get more travel the accelerator pedal is even with the brake pedal. That is pretty high. So Slade, I ask you, how far off the floor is your pedal?
Thanks,
Justin
Thanks,
Justin
