l3n
Quick question for the wiring gurus: could excessive engine compartment heat kill a relay?
I have a thermostat dual fan controller relay installed, with one lead going directly to an electric fan, and the other lead going to a separate relay connected to an electric water pump. After a couple of weeks, the relay somehow fused itself open (or closed?) so that it's now constantly on. It shouldn't be a matter of excessive current draw, since the controller is only powering a fan, with a separate relay for the pump, right? The fan's current draw is within the limits of the controller.
The reason I'm asking about engine heat is because I'm still fighting an exhaust leak that's strong enough to vapor lock the carb, and I noticed that the heat shrink on the wiring terminals have started to wrap themselves around the ends of the terminals too, which would seem to indicated the compartment is getting pretty toasty. Could that heat have also knocked out the fan controller? I have a spare that's half installed, but I don't want to push my luck til I get this figured out.
Thanks fellas.
Thanks fellas.
