red65stang
Active member
I know when you crank a car up that is cold it idels higher to warm the engine and when you would gas it alil it would come down on the idel. well when i took my carb apart to clean it last when i crank it up it starts at a high rpm but when i gas it alil it doesent lower the rpms, even when it nice and warm. i can drive it around after knocking the idel down with my finger on the carb, but as soon as i gas it, it goes back up to running at a high rpm. what did i screw up when i cleaned it?
