Gene Fiore
I went to the track last night and the car was running really good. The night air was cool and I ran some of my best times in time trials...15.25 and 15.26...all was good. Then first round came around and I dialed a 15.25 but lost the race to a 10 second car at the stripe. I stop to get my time slip and it is idling pretty rough and the car slowed to a 15.42 on that pass. I check the carb and timing at the track but still idling rough. This morning I pulled the plugs and they all looked pretty decent...a few were a little dark. I pulled the valve cover and everything looked fine. I decided to check the valve lash and every one was quite tight...couldn't even get the feeler guage in there. So I re-adjusted all the valves, check air fuel and timing and it is still idling really rough. Now what? Could a blown head gasket between adjacent cylinders be causing this? Is there a way to tell without pulling the head?
