Running Rough
tri-power 250":p0i4k407 said:
With your shortblock build and performance, an aluminum head and 4bbl might be what you need to get into the 13's.
I agree with your statement...if I had the money for that setup I would have it.
Gene,
I can only think of 2 things that could be causing your oil to manifold problem. Either when rebuilding the engine, when turning the engine upside down oil seeped into the manifold. May have taken awhile to settle to the lowest point in the manifold under the carb.
Or, is it possible its cooked down fuel looking like oil? I don't see that you have any real issues. You're doing the right thing by cleaning it out and checking it later.
Good luck getting into the 14's. Its looking good.
