Firepower354
I didn't notice, but you're not running an electronically controlled trans, right? That takes a Max
Order now.
FORD ARP 152-6001 ARP High Performance Series Connecting Rod Bolt Kits | Summit Racing
Free Shipping - ARP High Performance Series Connecting Rod Bolt Kits with qualifying orders of $109. Shop Connecting Rod Bolts at Summit Racing.www.summitracing.com
-material thickness above the pin
-pins with the order?
-pin length
-wall thickness:
-lock type(I assume press fit?)
-pin material
-piston to deck ht. Desired:
-do I need gas ports?
-pin fit yes or no?
-I’m not sure what CD means
From the cam card I got these numbers:
valve lift intake.448/valve lift exhaust.442(or should it be the lobe lift numbers?)
