Tri-Power N2O first test hit.......
64falconsix
Supporter 2022
Supporter 2018
First hit with 30 RWHP jetting netted excellent results. ......the shot hit hard and pulled strong....will be tuning for the 45 jets next ....I will eventually end up with a 60 or 75 HP tune.....20170217_132618.jpg
nice, very nice...
do you use an AFR gauge or any tuning aids while it's running, is there a practical limit with N2O without forged pistons?
haev fun
Please share your set up. I'll be certainly following this thread...
Powerband .....I did use a PLX wideband AFR which showed 11.7 at WOT but when I pulled the plugs I may jet up 1 size... according to my research I should be able to get away with 75 HP but i am now thinking i will go with either 45 or 60 HP.....since this is RWHP i was wondering if I would even notice the 30 HP hit but I was really suprised with the improvement especially in 2nd and 3rd gear.....VSSMAN..... I will post a few pics of the setup.....I used a Nitrous Express Hitman kit plate delete with 3 piranha foggers in custom 5/8" plates I had a friend water jet........also used a micro switch to activate at full throttle.......
Had 3- 5/8" aluminum spacers water jetted slightly different size than the carb gaskets on the first mock up.....used NX piranha nozzles because of their compact size.....placement was crucial for nitrous line connection.........this was the first test plate which was cut slightly larger......second set was cut same as the carb gasket.......
Second set complete and ready to install.......
I can certainly hear when the gas kicks in. Are you still running a progressive carb linkage?
Vssman.......still running Progressive linkage....was at about 1/3 throttle till 3,000 rpm then went wide open......really pulls hard and never lets up.......working on a set of custom forged pistons with an updated nitrous ring pack.......plans are for a 105 or so HP shot ........plans are 100 MPH plus 1/4 Mile runs.....built trans helps alot.........waiting for a little more testing and A boost retard/window switch install before moving much further past a 45 HP shot......
Excellent job! You might consider converting it over to solid linkage for even more performance when your racing. Good luck :nod:
