Vaughan_D_W
Active member
I should be getting a rebuildable 200 block and head within the next week or two, and I have to figure out if I'm going to go triple carb or turbo before I take it to the machine shop. Let me describe what I want the end result to be. The car is a 1965 Mustang.
Let me first explain that I'm not a "Mustang guy" in the traditional sense. It's the first one I've had and I got it because I made a trade I believe was favorable to me. To me, the the first-gen Mustang was the original sport compact, not a muscle car. I'm kind of picturing a domestic version of a modified MKI or MK2 VW GTI in my mind. Low, light, and lean, with a nice stance and good handling. I want it to be a reliable daily driver that will be a blast to drive on back roads, as well as manageable at freeway speeds. I have absolutely no interest at all in ever taking it to a drag strip. No interest whatsoever in drag racing, though I wouldn't mind trying autocross. I would, however, like to be able to shut the mouths of people who scoff at my six, so it should be reasonably fast. I used to have a 2000 VW GTI VR6 and it should have at least that much kick, preferably a little more. It should also not break the bank, as I'm currently in graduate school for a career that will leave me chronically underpaid. I'm not totally broke, though.
Other mods I know I want are a T5 (currently have a green dot C4), lowered suspension, and discs in the front. I'd also like to go 5-lug with an 8-inch rear and nice wheels. More or less in that order. But the engine has to come first, because right now i have a sickly 144 out of a 1960 Falcon in it, and I do not want to spend any money on that engine, so I'm building a 200.
Sooooo . . . I'm stuck as to whether to go triple carb or turbo. From what I've read, tri-carb is awesome (or at least awesome looking), but it's a pain to keep tuned and expensive to get set up. The turbo should be cheaper, but more work to get installed. It seems to me that the turbo also has more power potential. With a tri-carb, it's pretty much the carbs, an upgraded distributor, high compression, a cam, and headers, and you're at your power max, right? With a turbo, it seems like there's a lot more room to build serious power. And it seems like there's more room to build things incrementally. As in, I could start with just an Autolite 2100 and a DSII, and the car would run great. Then I could add a turbo and intercooler and all that later. And then I could upgrade my exhaust manifold later, and so on . . .
I already have an Offenhauser tri-carb intake. Jegs said it was no longer in production and they didn't have any, so I grabbed one from Summit just in case they really did stop making it. So that expense is out of the way. I already have one single barrel carb on the car, and I can get more for $75 each, plus $30 each for rebuild kits. And then air cleaners. That's it, right? Doesn't seem too bad. Is there something I'm missing? Then there's the tuning part. Is it really that much of a pain to keep them tuned once set up? My work will likely take me overseas for extended periods, and I'd like to be able to leave the car with my non-mechanically-inclined father while gone.
For the turbo, again, it seems like I could get away with just building a tough bottom end and then putting a 2-barrel and DSII on the car to start, and then going turbo as money comes along. I realize it will be a lot of work getting all the piping in order and getting things tuned up, but does a turbo setup stay pretty well in tune once you've got it dialed in? I do have access to a welder, by the way, though I'm still learning how to use it, and it's only flux-core at the moment. Oh well, ugly welds are ok as long as they work, and I'm willing to take the time to practice and learn.
So there it is. Half the reason I'm posted this is to organize my own thoughts on the matter. The other half is because I want to hear you guys' opinions on it. Am I missing anything? Are there any factors I'm not considering? I appreciate any feedback. Thanks.
For now, I guess I'm stuck trying to get the old 144 to run as smoothly as possible.
