Nick1966
Ok, after poking around the forums for a while I have noticed that I am the lowest man on the totem pole. So, once again I ask for your help to make me understand a few things about the tune up.
1966 Ford Mustang, 200ci, I6, Automatic Trans, Stock
Bubba gave me this information:
1. Gap your Spark Plugs (to .034) and install,
- I got this, put the spark plug gap gauge in the plug and bend it closed over the .34
2. set the Dwell on points (to 39 degrees),
- I understand what Dwell is but how is this set? At what points do I put my meter to get a measurement of Dwell? Is it the same points as getting the RPM over the Cap but with the meter set to dwell?
3. then set your timing (to 12 degrees BTDC)
- My dad had a timing gun he gave me but it has no instructions. Any information on this subject would be really helpful because I know nothing about this.
4. Next set your carb mixture to the lean best idle and last set the idle RPM (500 in Drive with brake set).
- Bring the engine to just about choking out and keep moving the screw back out until the engine levels out.
- I get the RPM thing now using the meter and adjusting the fast idle screw
Thanks for the help!
Also, since my other car has been totaled and I lost my job this is my daily driver and I can't really afford to bring it to a mechanic to do anything so I have to figure it all out myself.
congrats your now done with all the tuneup settings!
