The distributor center shaft size of .530 should be the same for all the years of the 240 or 300 sixes as well as most all other Ford OHV Engines from sometime in the 1950's on up.
I guess I'll have to order a melonized gear for an engine using the same shaft size and see what's different or the same from a 300? It doesn't make sense they would make a totally different gear just for those 2 engines....The distributor center shaft size of .530 should be the same for all the years of the 240 or 300 sixes as well as most all other Ford OHV Engines from sometime in the 1950's on up.
I believe the 240/300 uses a 16 tooth gear while most other engines use a 15 or less tooth count.I guess I'll have to order a melonized gear for an engine using the same shaft size and see what's different or the same from a 300? It doesn't make sense they would make a totally different gear just for those 2 engines....
I'm sure they can and especially if the OD of the gears are the same.Why couldn't the cam manufacturer change the drive gear count on the cam to match a 351W? They both have .531 shaft size. I need to get the O.D. of the 351w gear. Should be the same as the 302? I know the I.D. is smaller on the distributors I have had.
what intake is this thanksIf you have an old fence post, a drill press and a 17/32" reamer, you can do it yourself.
I used the original EFI fuel rail and just bent the injector cups to square them up.
Aussiespeedwhat intake is this thanks
tmc5150 I just called bullet because I got a hydraulic roller cam from them and at least on mine I cannot use a melanized steel gear has to be bronze or composite but they did say for an upcharge they could make it to where you could use a regular iron gear.
I hope that works. I would hate to ruin the camshaft if it wasn't compatible. Also when you called bullet cams what materials did they tell you they used?I called them a few weeks ago and they went over the different materials a roller cam could be made of and was very clear that a bronze or composite gear was my ONLY choice! I finally got him to tell me who made the OEM steel gears. Morel is the company. I tried to call them with no luck. I did find a company that sells their products. He told me he can get a cast gear of some alloy that can be run on 8620 and 9310 cams. He said that they make a bronze gear that is made of a very hard mixture compared to the other crap comp and others are selling. He said you can run high volume oil pump with them and he knows engines with well over 30k on them.
Here is a linkto their Facebook.
Sorry I can't remember what they said they used....I was just trying to get him to tell me who makes the OEM distributor gears and what types of metal was used for roller cams.I hope that works. I would hate to ruin the camshaft if it wasn't compatible. Also when you called bullet cams what materials did they tell you they used?
