Recommended Sticky
"Understanding Standard and Signature PIP Thick Film Ignition"
Ford is really clever, but TFi has some major issues because its not understood well.
It was born as an external "Hall" crank sensor EECIII but DuraSpark Brown Box DS II system in the 5.0 CFi /5.8/6.6 liter 2-bbl 1980-1984 Lincolns, 83-84 Mercury Cougars's and 83-84 CA Tbirds and some/most 351M and 400 California Bronco's and F-trucks and E-vans.
Just single synchronized Spark only system .
Since the harmonic balancer is 6-3/4" on everything, the 80-84, external D2-II Crank triggered parts can be used to fix up a TFi that isn't Dual Synch.
But in 1984, Ford Had a Better Idea
TFi = Thick Film Ignition
PIP = Profile Ignition Pickup, the sensor inside the distributor.
The PIP system uses a Hall cell magnetic sensor, which is a prox sensor, a distance ranging device that generates a reference and zero voltage as the Shutter Wheel passes between it and the Magnet. It is three parts.
TFi's are Dual Synch for Sequential Injection 5.0's, but Single Synch Bank fire on 5.0/5.8 trucks till about 1995. They are not the same. The one year only 84.5 to 85 Automatic TFi was similarly unique.
Get the wrong parts not up to quality, and the sensor will stop transmitting.
Replacement parts have a terrible reputation. Ford OEM, reasonable, although they too are suffering from some approved supplier problems.
If the distributor is not forming a Square wave to the Injectors and another modified square wave to the SPOUT , the car will break down at various RPMs.
If its not working, then you have to get an aftermarket Hall Sensor and you must check the PIP Shutter wheel for magnetic quality and the spacing of the narrow shutter.
later Ford 5.0 distributors are solid, no mechanical or vacuum advance.
Just a simple rotor with PIP gates and a Hall Effect sensor.
The signal should be stable (Without Scatter)
the module is this
the shutter wheel that forms the PIP signal is this
the shutter wheel triggers a square wave electrical signal using the Hall Effect sensor
See https://www.w8ji.com/distributor_stabbing.htm
the module is this
Drag Radial Performance":2jfs4vwl said:Here's a Picoscope waveform of what Ford TFI ignition signals look like. The blue signal is the PIP sensor inside the distributor, short for Profile Ignition Pickup. This is called the PIP signal, and it's how the distributor tells the ignition module and the PCM when a cylinder is at 10 degrees before Top Dead Center. One out of every 8 pulses is narrower than the other 7 are. This is called Signature PIP, and represents Cylinder #1 is at 10 degrees before TDC.
Once the PCM knows which cylinder is #1, it can fire injector #1 at the correct time. To fire the other 7 injectors, it doesn't need a special cylinder identification. The PCM just counts from 1 to 8 in the firing order - 1-3-7-2-6-5-4-8.
The green signal is called SPOUT, short for SPark OUTput. The computer receives the PIP signal, modifies the timing of this signal to reflect the ignition advance timing it wants the coil to fire at, and sends this modified signal back to the ignition module. The ignition module then fires the coil based on this SPOUT signal.
If the SPOUT signal is not present, the ignition module creates it's own SPOUT signal that is identical to the PIP signal, and fires the coil based on that instead. This is what happens when either the PCM loses communication with the ignition module, or when you unplug the SPOUT connector to set your timing. Unplugging SPOUT literally cuts the wire going from the PCM to the ignition module.
The notches you see in the top of the PIP and SPOUT signals are reflections of the one signal's edge in the other. Presence of these notches indicates the ignition module is receiving a SPOUT signal OK. The TFI ignition system can be standalone. It does not need the PCM in order to fire the coil. It only needs the PCM to alter the timing of the coil firing, to create the proper ignition advance. Without the PCM, the ignition will fire at 10 degrees BTDC every time, if that's where your base timing is set to.
These ignition signal waveforms were captured using a Picoscope 4423 4 channel digital storage oscilloscope. It's basically the world's fastest graphing voltmeter. Each one of these blue PIP signals lasts for about 11.32 milliseconds at an idle speed of 672 RPM. A typical voltmeter will only update about 4 times per second, or once every 250 milliseconds, which is nowhere near fast enough to capture these events.
At 672 RPM, one PIP signal lasts about 11.32 milliseconds, or 11/1,000 of a second. At 6,000 RPM, one PIP signal will last for approximately 1.25 milliseconds, or 1/1,000 of a second. A scope could capture that as if it were in slow motion. This scope can measure signals as fast as 1/2 of one nanosecond. Nothing gets past this scope. If you're at 6,000 RPM and one single PIP signal is missing, causing one cylinder to misfire one time, a scope can catch it in the act, which is why a scope is perfect for diagnostics.
At Drag Radial Performance, we specialize in these classic 5.0L Mustangs. Despite their age, we're moving the hobby forward in technology, picking up where these cars were left off 20 years ago, and applying today's technology in tuning and diagnostics to them. It's a great time to be rolling in a 5.0!
