XY 250 Electrical gremlin
71ford
Active member
Hi,
I have pick up a weird electrical gremlin in my car (XY 250). It started as I was driving that the indicators stopped working, no clicking, no anything. I had a look at the fuses behind the accelerator pedal but they all appear intact.
When I checked the other electrics in the car I found that the wipers do not work either now. However, the horn does work as well as lights.
I know the indicators themselves work as when I lock the car with the alarm they all go off.
Any ideas please? or at least where I can start?
Thanks
Blinkers might be the flasher can. grab a multimeter and see if you are getting power to the wipers. You may have 2 totally seperate faults at the same time. These old girls are pretty simple to fault find
I agree sounds like your alarm system will still flash the lights so it should be a simple fix with some patience to find the faults.
