What I am going to do have the block decked a small amount and make up for it in CH of the piston. I made the head gasket .040 to account for the piston sticking .010 out the hole. I'm sorry if I confused y'all with my info.
69stang_250":1advazyo said:Puller - I am going to clean and polish the rods in the next day or so. I have done polishing on metals before so I'm sure I can tackle that and then get the machine shop to shot peen them for me. Yeah, that is why my views on the forged Pistons have changed. Once you get above 5300 rpm those piston speeds are at or above 3500 fpm and I've read that is about the limit on stockers.
Bobcat - I think you have your math wrong man. Here is what I am using and how I got my compression numbers. I may go with a 56cc Combuation chamber to get the 10:1 or I'll adjust the piston dish volume.
69stang_250":npt296yx said:Maybe I am reading the cams wrong.
I know what you mean and I am one of those guys that like that lol
I have a 77 280z and it doesn't "kick in" until 2300rpm. From there that car would get up and go!
So help me understand the difference between the 108 and 110.
I figured the 108 would be similar to the 274 110 cam but with more lift.
I really don't want the engine to be a complete turd off the line, but I can live with a little bit of a delay of power.
69stang_250":2zswf9x2 said:So if I went with the 110, what would be the characteristics of it? I don't want to completely kill the lower end, but ultimately, I do want to be able to run this thing down the strip in the 13s.
Lol I always enjoyed it, but when it comes to it, I enjoy the driving experience as a whole lol
69stang_250":376wbrd1 said:So the stock piston has a 1.500 CH and when I measured the deck height, it came out to .117 while the Pistons were still in.
Now take a piston with 1.585 CH and that will drop the deck height to .032. So I'll just have to shave .042 off the deck or get a piston made with that much extra on it.
69stang_250":180hp2w4 said:Yes I thin you thought was wrong then.
so the smaller the number, the better performance on the upper end?
