350 cfm HOLLEY carb and a Redline Torker Intake Manifold
I have just recently acquired a redline torker intake manifold and a 350 cfm double barrel holley carb for my 86 XF manual ute and was just looking for help on how to put it on and what to do the extra heater hoses from the old manifold. im just not sure because the hoses went through the manifold so what do i do please HELP!!!!!!!
its pretty easy you just unbolt your old one and bolt the new one on,make sure you have a manifold gasket.if the manifold has no heater hose fittings you simply cut the hose and join the two heater box outlets in a U shape with the old hose thats there.
just join the two hoses that went into the manifold together. then you should just have one hose from the head to the firewall and one coming back from the firewall to the waterpump.
Thanks very much guys i really appreciate the help i just wasn't exactly sure what to do but know i have somewhere to start muchly appreciated.
I also need help with the heater hoses. This is how I think it goes. I have the two conections coming out of the firewall. I'll call A and B. Where B is the where the vacumn actuator is for the heater. Then I have the two conections on the head. I'll call C and D. C is on top. E is the conection on the water pump. F and G are the two on the intake. G is a tee connector. This is how I think it goes:
A goes to the tee on G
B goes to C
D goes to F
E goes to the tee on G
