Will high impedance siemens deka 107961 60 lbs. 630cc work? They say they idle well on the smaller grand national engine.
Sorry about that. LOLPaul, you are not helping me get rid of the physically too long inj. for what I am doing.The vender wrongly sent me, when I ordered short length.
You can buy individual 44 lb/hr Accel injectors.
Part # 150144
I don't know how much fuel flow the stock rail will support before seeing a significant pressure difference from one end to the other.Will a stock style fuel rail support the flows needed for that size Injector, or would I be looking for a made to fit rail?
Found success with the late model EFI aluminum thermostat housing. its shaped a bit different than the carbureted cast iron unit, and it clears the Aussiespeed valve cover.
I really like that valve cover, is it your own design?Funny to see this. I had the same problem. I put on an old thermostat housing and thought I made a mistake with the VC design until I remembered the taller housing.
Is that the new intake you’ve been working on?Funny to see this. I had the same problem. I put on an old thermostat housing and thought I made a mistake with the VC design until I remembered the taller housing.
Yeah it's a prototype to test on my truck and see if I need any changesIs that the new intake you’ve been working on?
What will you use for a longer hex drive for the oil pump?I ultimately ordered 3 thickness - mostly to meet the order minimum - 0.119, 0.250, and 0.375. I thought for sure the quarter inch would be the one and almost didn't get the thicker one, but glad I did because the 3/8" thick was the winner.
Likely just order some hex bar stock and trim to length. I don't remember what size it is off the top of my head, but I remember it being pretty standardWhat will you use for a longer hex drive for the oil pump?
