Hey Guys,
I thas been a while since I have been able to turn a wrench on my Mustang since I have been at school, but I am still being plagued by my engine vibrations a year later. The engine ran great when I bought the car, and through a fit of bad luck, the engine harness fell while I was driving and melted/shorted out on the exhaust causing the car to misfire, and run like crap. It back fired a number of times, and I ultimately had it towed home. I fixed that problem, and then had the transmission rebuilt. Thing is, there is a vibration in the motor that builds as the engine revs. I know it is not the U-joints because it does it while sitting still in park. So far I have replaced the points, plugs, wires, harmonic balancer, rebuilt the carb, and done everthing I can think of. The car still vibrates. I have taken it back to the Transmission shop and they say it is not in the transmission or the torque converter. I can't honetly say if the vibration was there before I took it to the shop or not, but I think it might have been there after I started the car up after fixing the wiring, again not sure. What are some other possible things that would be causing this to happen.
Your help is greatly appreciated.
Jon
Jon
