Hi guys, a question to ID my Weber/Motorcraft. I don't have any numbers except the base plate has the numbers  "R  6309-1". The bore numbers are 26 and 27. The name on the carb is Motorcraft, no other mention but it appears to be a 5200 if I remember from my Pinto and it has a water choke. Also if someone knows about this carb, what is the diaphram next to the choke for? There's no linkage off of it, it seems to go directly to the choke and the number 6583 is stamped on it.
Thanks in advance,
Steve
			Thanks in advance,
Steve
