200ci Degree the cam?
This applies only to 200ci
Dustyford
Hello all, I installed a reground original 60s cam earlier this year in my ‘65 200. I did not degree it. It is a mild performance grind. I was told bolt it in and go. It is a new rebuilt engine and doesn’t idle well, doesn’t accelerate well, has weak, unstable vacuum at idle and won’t rev over 3800. I have been chasing carb and ignition as the cause but maybe it’s the cam. Where can I find a cam degree kit for a 200? Thank you.
Who reground the cam. I had Schneider regrind a 200 cam for me and it was so far off that I threw it away and bought a Clay cam. I was very happy with clay cams and they had many in stock to chose from. I had them send me all the cam grinds in stock and I picked one.
Yes you must degree the cam. To many horror stories and personal experience.
Hi, in the search box, look up Echo 1955 videos. I checked the link and it works. Echo 1955 documented his engine rebuild in a fun and educational way. You will see the piston stop, degree wheel, and dial indicator in action. Echo 1955 shows how to measure the cam events and do the math. Bubba made sure the videos were preserved. Unfortunately, we have lost both of these members. Good luck.
Thank you. And thanks to those who gave so much.
It was Oregon Cams. I am posting a photo of cam card.
You only need to check for a big timing error at the camshaft that would cause your engine to run badly.
Looking at the cam card, the #1 cylinder intake pushrod would lift .050" at 7 degrees ATDC.
See "Cam Timing @ .050" Tappet Rise:" where it shows Intake Open -7 BTDC
-7 BTDC translates to 7 ATDC
If you want to double check using the cam specs shown in the upper half of the card.
Cam timing Lobe center line is 108 ATDC
Intake duration @ .050" is 203.
From the center of the intake lobe to the .050" lift point = 203/2 = 101.5 degrees
108 - 101.5 = 6.5 degrees ATDC.
Round up to 7 degrees ATDC.
Remove the valve cover.
Then turn the crankshaft clockwise until the #1 intake pushrod is all the way down and the #1 intake valve is closed.
Then put a dial indicator on the #1 intake rocker arm just over the pushrod and zero the dial.
Then turn the crankshaft clockwise slowly until the pushrod end of the rocker arm rises .050" and stop.
Look at the timing mark on the harmonic balancer and it should be close to 7 degrees ATDC.
Thanks. I will have to borrow a dial indicator and get back to you.
Here is picture of the line at .050 open. It seems quite a bit more than 7* ATDC. White mark at top is 10* BTDCIMG_6789.jpeg
The cam card asks for the intake lobe center to be at 108 which is 4 degrees advanced when the .050" point is at 7 degrees ATDC.
The intake lobe center appears to be retarded from 7 ATDC position but even if it is at say 15 degrees ATDC that would put the cam 4 degrees retarded instead of 4 degrees advanced which would not make the engine run poorly.
It would simply shift the power band higher.
The stock 300 six cam is run at 4 degrees retarded.
You can check the timing again with the #1 intake valve adjustment loose so that the valve spring is not pushing down on the lifter plunger at .050" lifter lift.
After this exercise, I would do a compression check on all the cylinders just to be sure the engine is fine mechanically and all the valves are closing.
After this exercise, I would do a compression check on all the cylinders just to be sure the engine is fine mechanically and all the valves are closing at the correct valve timing.
Thanks P. I have 150-160 psi compression. So I shouldn’t have to degree my cam then? Any idea why rpms are limited?
If all the cylinders have between 150 and 160 psi, your cam timing is ok, the valve train is OK and the engine is fine mechanically.
Next question is: What does the ignition timing look like using a timing light?
I have been playing with the carb for months. I try to keep the timing at 10* BTDC as you can see the white mark on the timing scale on the timing chain cover. Whether I’m running my idle at 520 or 750 trying to get it to run better I always start with 10*. It’s never a steady 10*, moving from 9.8-10.2 or so.
I’m really sorry to drag you into this. I can’t pinpoint for sure. It may be when I installed the cam. I installed the new distributor and ‘68 carb at the same time. I have threatened myself to go back to the stock cam, LODO, and SCV carb. 😥
The cam is giving you between 150 to 160 psi on all cylinders so there is nothing wrong with it or the rest of the valve train
Well I had low rpms with the SCV carb and LODO. I have been told I should get 4500-5000 rpms fairly easily. Of course I had better vacuum with the stock cam. 18” versus 14”. The 14” vacuum reading flutters between 12” and 14”
