edgewood bronco
Okay. I think I'm making progress on degreeing my cam, but now have come up with two different answers depending on what method I use.
First, I have a Classic Inliness Product ID: CSC-264-HSP-10; 264/264-110* Hydraulic Cam. I've spent most of this afternoon researching this site and going back to the block to make sure I'm doing this right. I've watched various youtube videos including the one on the 200 six build.
Using the Centerline method, I get readings of 152.5 and 59.5. take an average and I'm at 106. Right where I should be, no?
Using the Duration at 0.050" method, I get readings of 4 and 145. I was really confused until I realized I really should have had a degree wheel that goes all the way to 360, so my duration is really 4 +180 +35, (right?) = 219, divide by 2 and get 109.5.
What one do I use? It's supposed to be ground straight up, so I'm inclined to go with the second one.
What about the coating on a new cam lobe? can that screw up these readings? I don't have any assembly lube on there, just a bit of oil but not sure if that might introduce error.
What about the 219 degrees of duration I'm getting? Isn't it supposed to be 214? according to here: http://www.classicinlines.com/proddetai ... 264-HSP-10
Shall I try no. 2 intake and see how that stacks up? My dial indicator is straight with the lifter, so I think I'm getting reliable measurements.
Thanks!
Andy
Thanks!
Andy
congrats
