BIGREDRASA":1jvo0zaq said:I'm going to weigh in with a simplistic suggestion (not always bad). The problem you have is in working with two unknowns. If you can reinstall the Holley 1100, do so, and see what happens. I know it won't perform too well with other than Loadamatic, but it should at least run.
Bort62":18xx9ems said:BIGREDRASA":18xx9ems said:I'm going to weigh in with a simplistic suggestion (not always bad). The problem you have is in working with two unknowns. If you can reinstall the Holley 1100, do so, and see what happens. I know it won't perform too well with other than Loadamatic, but it should at least run.
The carb doesn't care what distributor is on the motor...
However, the ignition system is so simple that it's fairly easy to make sure that is all working properly, and then focus on the carb.
BIGREDRASA":132fv21m said:On another post, someone wrote that wires were incorrectly shown on someo diagram. Anyway, here's the diagram I found on this or some other forum:
Being partially color blind is always a challenge, but I can tell Orange from Black and Purple (or Violet, Chartreuse, whatever.) The way I read it, Orange to G, Purple to W, C to Neg post on coil, B to Pos post on coil with 12 Volts Switched. Is that Correct? I've got mine just about hooked up, with the Holley 1100, except for timing.
Bort62":jhtsnqpm said:OKay, look up.
This is the correct configuration
This has been gone over already in this thread. Too many damn threads to keep track of!![]()
BIGREDRASA":3tj3kf5w said:Bort62":3tj3kf5w said:OKay, look up.
I couldn't even find where I got the diagram above. That's why we need certain comprehensive Stickies.
I can't quite see the lettering on that module. Do they all have the same terminals/lettering? That looks pretty much like the diagram I have, assuming C is black and Neg, B is Red and Pos, Purple to G, and Orange to W.
Bort62":3lne77hk said:In reference to our previous discussion re: stickes, what we (you) really need to do is go through the stickies we have and trim out the non pertinent information and then lock them. It's pretty cluttered in there.
