I just got a 69 bronco with the 170 I6. I am trying to swap the duraspark 2 in from classic inlines.
I installed the distributer but the truck has a centech wiring harness installed so the ignition switch is wired differently than the stock switch. Im having trouble figuring out which wire to cut from the ignition switch.
Should I get an adapter and install a factory ignition switch? or is there another easier way to wire the duraspark 2 to the centech harness?
Thanks
George
Thanks
George
