So I posted in the small block section about cam selection recently, but got told that my comp of 9.4:1 was far too high to run pump gas. I am posting over here to get a conformation on my build so I don't destroy anything.
The build is with my 170cid six, hopefully transfered over to a 250 when the funds arise.
I had planned on doing a modified log or alum head for some time, but just now got funds. And honestly for the extra few hundred bucks alum is the way I'm going so I don't have to do it twice.
On my little engine I want to run either a 264/264 264/274 or 274/274 cam at either 108 or 110 lobe center. but not sure if I need dual pattern for a street engine or if 274 is far too overdone for the smaller engine. I have a 2.77 trans that I just rebuilt replacing some of the more worn gears in it, but intend to swap to t-5 in the future.
Like I said this will be a street engine and might see the strip once in a blue moon down the line, but am lookin primarily for something that run a Honda off the stoplights.
I would like q bit of an idle to her, but not if that sacrifices performance.
carb will likely be an autolite 2100 but can figure out what CFM when the time for that comes. It will include a header and probably 2" dual exhaust.
I just want to get some decent answers before putting in this order and not just be told what is wrong with my plan, but not how to correct it.
Thank you for any input.
Gerald
Gerald
		 I run 9.3 on regular gas, 91 oct (only for MPG purposes...) could run 89 or 87 just fine(~8*static), but I run the higher 91 to add timing (mpg) (currently 15* static)
