You are right, lifters were not full with oil. The car has been sitting for a week. I can pump oil with power drill, but not sure if that’s enough.No i meant the rest of the valve lift, some 6mm of it? Lifters not full of oil?
I put pushrods to 3 intake and 3 exhaust valves on different cylinders, all of them are close to be the same.The valve lift should be .420"
Check the lift at another cylinder.
I get 0.270” - 0.272”, when I measure just the pushrod movement. Checked all 12 of themPut the dial indicator on the pushrods without the rocker arms in the way and check the actual lobe lift.
The lobe lift should be .280”
Ok, the camshaft appears to be good without any lobe failures.I get 0.270” - 0.272”, when I measure just the pushrod movement. Checked all 12 of them
Got my compression checked. Dry and wet - same numbers pretty much. The compressor tester I’ve borrowed, doesn’t stay stick to the max for some reason, so numbers are as close as I could catch them. But everything looks pretty solid, as I understand.Ok, the camshaft appears to be good without any lobe failures.
All good, no worries there!Got my compression checked. Dry and wet - same numbers pretty much. The compressor tester I’ve borrowed, doesn’t stay stick to the max for some reason, so numbers are as close as I could catch them. But everything looks pretty solid, as I understand.
1: 175-180 psi
2: 170-180 psi
3: 175-180 psi
4: 190psi
5: 180 psi
6: 180 psi
Got the rocker arm yesterday and will fire it up again soon without valve cover to make sure that everything is oiling there.
Does it come with pushrods? The adjustable rockers use a ball and cup pushrod and won't work with the regular ones. I think it might be a good idea to grab that set and rebuild it as necessary. It will give you the ability to dial in the valve lash more effectively than the fixed rocker arms and that might be a good thing since todays head gaskets are much thicker than the ones these engines shipped with. Also, if you do decide to shave the head to bump up compression, you'll need the ability to adjust the valve-lash in the other direction.Side questions, does this adjustable rocker arm looks like worth $100 and shipping (probably about $140 total)
Rockerarms unlimited in Redding, CA will rebuild it.Does it come with pushrods? The adjustable rockers use a ball and cup pushrod and won't work with the regular ones. I think it might be a good idea to grab that set and rebuild it as necessary. It will give you the ability to dial in the valve lash more effectively than the fixed rocker arms and that might be a good thing since todays head gaskets are much thicker than the ones these engines shipped with. Also, if you do decide to shave the head to bump up compression, you'll need the ability to adjust the valve-lash in the other direction.
