Thanks, I’ll try plugging PCV and double checking distributor and spacer. I’m pretty certain I dropped it the right way…#1 piston is at TDC, drop the dizzy, line up the mark for first spark plug to the rotor.
Will come back to it later this week and reinstall everything…
I was using ported vacuum on the front of the carb. But when I was starting it now, vacuum line was disconnected and plugged at the carb.
Verify that you are on #1 compression stroke, not exhaust stroke. both #1 rockers should be slack. Backfire in carb is late ignition timing 95% of the time. If you turned the engine with the distributor out you may be on #1 exhaust cycle, the ignition timing is 180* late if so.
Vacuum advance is not a factor at cranking speed.
