I recently bought this Falcon on a whim and I am trying to figure out what to do with it. It runs and drives, but there are clearly some timing and shifting issues.
Here's what I know. It's pink. It's awesome. It's straight and solid.
Here's what I don't know. What the heck the drivetrain is made of. I know that the owner blew up the original motor beyond repair (windows install) and had a shop put a motor/trans in it. He was told it was a 200/3 speed auto that was installed.
It was originally a 2 speed auto. Now it's what I think is a 5 bolt case fill C4.
The head is a C5DE-6090-A. The block is a C1DE-6015-A. The carb is chinesium Holley flavor but without the SCV port. The distributor appears to be a load o matic.
The car runs and drives, but the advance/spark is of course jacked up. You can drive it, but its pretty apathetic till about 40mph in 2nd gear (sorry, no tach) and then the timing appears to come in all at once and it runs like a champ.
I am trying to figure out if it's a 170 or an early 200. It has three freeze plugs. It does NOT have a T or an N on the flat above the downdraft hole. That stamping reads M-2580. Can anyone offer any advice? or it is just pull the head and measure?
