Junior64":8nj83nnh said:am comfortable with the way it's set up since it runs great.
Well, after all the tech & specs that's what it really come down to, 'hows it run'
...nice to sit back and enjoy the ride :vert
For future reference here's a page with the ratio of scv port vac(hg) to advance(degrees) specs...
http://falconfaq.dyndns.org/display1.ph ... Page=9-030
And a thought for determining total advance once she's off the scale is to use a 'dial back' timing light (will let you clock the degrees on the timing light until the flashing light returns to TDC and determine advance at a given rpm).
EDIT: One last thought...consider the pertronix upgrade. Probably easiest anc cheapest electronic ign upgrade given your current setup. if you want a nice performance wake-up & no more changing/adjusting points
Good luck with your bird
