Really ?
Hmm - what is DXF, all I am familiar with is Autocad.
The more I think about it however, the More trivial it seems. For an exhaust flange there is no reason to attempt to match the size of the port.
Using a hole saw of Diameter larger than the Diagonal of the port would suffice, especially if said hole saw produced a hole ID which was slightly larger (snug fit) than an existing Tubing ID. would make welding the Primaries to the Flange Much easier.
Having the header primaries larger than the exhaust port Will only help with reversion ( not that there is likely to be much under boost ) And won't hurt unless grossly oversized ( im not talking 2' primaries here )
The only tricky part will be the center Siamesed exhaust port, but that could easily be accomplished by Two holes of Said Diameter next to each other.
Because this is going to be a boosted application, I can get away with alot more in terms of minor deviations from perfect flow.
better pick up some stock On Friday, perhaps.
