67Straightsix
It looks like you are still running too hot. I don't think it's gas, I think it's heat. Stainless is tricky - there's a fine line between a perfect weld and too much heat. If you have some scrap tubing, practice butt welding two pieces together with out filler rod. This is a good way to get a feel for the correct heat and you don't have to worry about dipping the rod. Just concentrate on the weld puddle - if you have your amps and fit up correct the weld puddle will flow very nice. It's a good way to get use to welding stainless without worrying about the filler rod. Looking at the picture you should always fill your craters. You have the technique, it just takes practice.
