clintonvillian
This thing has stalled momentarily (Getting the Bronco in summer shape so me, wife, and kids can enjoy the warm weather). As such I have been doing some research.
Here is a picture of the actual lightning solenoid that operates the vacuum diaphragm on the M112. The diaphragm has two ports, one is a "manual" in which if vacuum is seen on the engine intake manifold, it will open the diaphragm allowing the air to bypass the rotors.
The second nipple connects to the solenoid in the picture. When the computer sends a signal to the solenoid it in turn opens up, allowing vacuum to be seen at the diaphragm and opening up the butterfly valve.
My question now becomes is the an all or nothing solenoid. I assume it is 5 volts? Would you guys think that is correct? Does it have to have a full 5 volts, or is it variable so that at 1 volt it lets some vacuum through and cracks the valve?
What do you guys think?
If I buy it is there any way to test it?
