8) other than jetting, to make a carb ready for a blowthrough install you either need to modify the base plates and vents, or use the same approach that paxton did and seal the carb in a box. for a draw through set up you really only need to rejet the carb. also as stated the floats on the blow through setup need to be solid to prevent collapse and you need to run higher fuel pressure to compensate for the boost pressure.
