Would it be a good idea to swap over to msd ignition, my car comes from the factory with electronic ignition.
Are the wastegates on most turbos adjustable? i plan on getting one from a junkyard or on ebay. is a mitsubishi TEO4H a good turbo for a 225 ci motor?
can you run a choke on a carb with a blow through turbo?
do you run a blow off valve at the same psi as your wastegate is set at?
